Caller ID not working
wrinklie1
Have tried #234# to no avail. what info is needed to correct this?Huh
4 REPLIES 4
JOLO
Fixes: 77
Re: Caller ID not working
Hi @wrinklie1,
To check if caller display is switched on it's * # 234 # if it's on you'll get the message "caller identity will be displayed". If it's not active you'll need to type * 234 #.
Could you try this again with the correct code?
wrinklie1
HI
My dect phone doesn't appear to have the facility to enter spaces, so unable to try your suggestion
JayG
Fixes: 6
@JOLO must have got twitchy fingers - there are no spaces. Wink
JOLO
Fixes: 77
@wrinklie1 Sorry, I added the spaces just to make it easier to identify the symbols/make it look a little cleaner. As @JayG has advised spaces aren't needed.
