Caller ID not working (still!)
nippersmum
I have been with Plusnet now for a couple of years and am pleased with the service but one thing which has never worked is Called ID. It is selected as a call feature but still does not work. Any ideas?
1 REPLY 1
Fixes: 251
Re: Caller ID not working (still!)
Sometimes it does not “take” into BT’s systems. Does the account indicate changes in progress?
You might try removing the option and later re-adding it. If that fails you need assistance from support, either here or phone in.
