Caller Display, Voicemail and Plusnet Call Protect not working - really need help.
molly8
None of these services are available to me although all have green lights on your website indicating that they are active. I really need these, particularly the first two and would be grateful if anyone could help.
Thanks, (and apologies if I have posted this twice).
5 REPLIES 5
Legend
Fixes: 246
Re: Caller Display, Voicemail and Plusnet Call Protect not working - really need help.
@molly8 Have these worked previously? Have you recently changed your telephone(s)?
molly8
Have just changed from BT to Plusnet - using same phone(s) which previously had these services with BT and I was assured would be transferred to Plusnet..
Legend
Fixes: 246
Ah, OK. Sorry for more questions, but when was 'just transferred'?
MatthewWheeler
Fixes: 478
Thanks for your post @molly8
It looks like the feature wasn't added on our supplier's end.
I've done this for you now and it should be up and running within the hour.
If there's anything else we can help with let us know
 Matthew Wheeler
molly8
Thank you very much, Matthew.  Seems fine now.
