Call plan minimum term
- Home Phone
- Call plan minimum term
23-11-2018 10:57 AM
Hello, can anyone tell me if I purchase an add on call plan, is there a minimum term I need to keep it for please? I understand it won't start until my next billing cycle, but I can't seem to find on the T&Cs for if/when I remove it. And it looks like I can't do it myself online as I have line rental only at the moment?
Re: Call plan minimum term
23-11-2018 3:22 PM
There's no minimum term for call plans.
To order, log into your account and select "Product Change".
Broadband comes up first, so select "Keep this product". Then tick "No hardware" and "Continue" - and you're then at the stage to select a call package.
Zen SOGEA 40/10 + Digital Voice FRITZ!Box 7530
BT technician (Retired)
23-11-2018 5:08 PM
Thanks!
23-11-2018 6:25 PM
You're welcome.
Not obvious is it - but that's Plusnet.
