Call plan minimum term
karenj
Hello, can anyone tell me if I purchase an add on call plan, is there a minimum term I need to keep it for please? I understand it won't start until my next billing cycle, but I can't seem to find on the T&Cs for if/when I remove it. And it looks like I can't do it myself online as I have line rental only at the moment?
3 REPLIES 3
198kHz
Fixes: 39
Re: Call plan minimum term
There's no minimum term for call plans.
To order, log into your account and select "Product Change".
Broadband comes up first, so select "Keep this product". Then tick "No hardware" and "Continue" - and you're then at the stage to select a call package.
Murphy was an optimist
FTTC 40/10   Billion 8800NL
BT technician (Retired)
karenj
Thanks!
198kHz
Fixes: 39
You're welcome.
Not obvious is it - but that's Plusnet. Roll_eyes
