Call Charges included in plan
measha06
I have unlimited UK telephone calls in my plan when we join on 19th. Can somebody tell me if like BT each call has a max of hour to be free or are any duration of calls free?
6 REPLIES 6
Fixes: 1,652
Re: Call Charges included in plan
Inclusive calls are indeed only up to the hour
Fixes: 558
Calls become chargeable after an hour. You can find the full details here https://www.plus.net/help/legal/residential-phone-tariffs/ it's under the ' how we charge for calls' section
measha06
Thanks I cannot see the mention of an hour anywhere
measha06
Does it apply to mobiles as well?
Fixes: 1,652
Yeah it applies to both mobile and landline calls
pjmarsh
Fixes: 24
@measha06, if you expand the "How we charge for calls" section on the link @MisterW posted, you will have this at the bottom of that section:
