Another landline porting question
mystreet1
Seasoned Pro
Fixes: 7
Re: Another landline porting question
You have 30 days to port it from today. If you have a phone plugged in dial 17070 and note the number. You may have been provided with a temporary one.
Was a member for years, but moved from PN fttc to fttp from an AltNet. Getting 940Mb up and down. Happy to stay on here and try to help others. 
Fixes: 579
@Racalman as soon as you've got the confirmation email from Plusnet that your product change icomplete, you can start the port
Racalman
Great, thanks guys. I just checked the phone again and it's dead now, so let the porting commence!
Mike
Racalman
A quick update. The port went through and my landline number is now working from my A&A SIP account.
Much easier than I was expecting!
Mike
