Adding phone numbers to Call Protect
benrm
To add a number to call protect do I have to answer the call on my handset or can I let it ring until they ring off and then add it using 1572?
I'm unable to connect to 1572 although call protect shows as being active in my account.
6 REPLIES 6
Legend
Fixes: 255
Re: Adding phone numbers to Call Protect
Hi @benrm . That looks like a two-part question Smiley
If you want to add a number to the blocked list, unfortunately you do have to at least accept the call, although if you know it is fake/unwanted, just accept it, then close the connection without speaking, then you are able to 'add last accepted call to the blocklist'
What happens if you try to access 1572?
benrm
I get the message 'this service cannot be connected'
Legend
Fixes: 255
Ah - OK. In that case you need to contact Plusnet and ask them to remove/reinstall and activate it. This is a recurring problem with a simple solution.
198kHz
Fixes: 41
@benrm When it's up and running, you may find this useful if you haven't seen it -
Call Protect PDF
Murphy was an optimist
Zen FTTC 40/10 + Digital Voice   FRITZ!Box 7530
BT technician (Retired)
linduf
Thank you so much for the spreadsheet of 1572 options, very useful and hopefully will help me stop many nuisance international calls at least. I hadn't found my way into the Option 4 settings menu.
198kHz
Fixes: 41
