ALR do I get free calls to the Plusnet Helpdesk?
FIXEDTopic Options
- Home Phone
- Re: ALR do I get free calls to the Plusnet Helpdes...
26-05-2016 5:39 PM
Title says it all but thought I'd check. I know with a call plan this is the case but not sure with ALR. TIA.
Don't use a big word where a diminutive word will suffice.
Fixed! Go to the fix.
Message 1 of 3
(703 Views)
2 REPLIES 2
26-05-2016 5:40 PM
Yes. It's an 0800 number
Re: ALR do I get free calls to the Plusnet Helpdesk?
26-05-2016 5:41 PM
Thanks I've never had to call so never looked - should have done that first. Thanks again.
Message 3 of 3
(696 Views)
- Home Phone
