60 minutes and counting...
- Home Phone
- Re: 60 minutes and counting...
29-04-2013 8:20 PM
Not a complaint... just a question.
Why, with the free calls package, is there a limit of 60 minutes with the option of redialling again immediately?
My only thought on this is that some people may be caught out by not watching the clock adding a cost to the otherwise 'free' call.
But, I would expect that most are savvy and do simply hung up just before the 60 minutes and redial. So, isn't it about time this limit was dropped?
If I remember correctly some companies already have dropped this limit (Virgin?).
Forum Moderator and Customer
Message 1 of 5
(1,226 Views)
4 REPLIES 4
29-04-2013 8:24 PM
I suspect it might date back to the days of hooking up two sites with modems - if you had to disconnect every 60 minutes then you couldn't use an "unlimited" package for dial up access etc.
Message 2 of 5
(426 Views)
29-04-2013 8:30 PM
£1 kitchen timer set to 50 minutes does the job.
I usually initiate the call on the hour, which gives an easy indication of Time passed.
And....
http://community.plus.net/forum/index.php/topic,112394.msg963608.html#msg963608
And....
Message 3 of 5
(426 Views)
29-04-2013 8:36 PM
Forgot about that thread
Message 4 of 5
(426 Views)
29-04-2013 8:41 PM
My GF & myself used to be on Orange, with a plan that gave us 30 minutes of "free" calls per day.
I seem to remember the plan cost £15 pcm.
We used to phone each other every evening, and 30 minutes x 2 was just about right.
Then..............
For no extra cost........... Orange increased the "free" daily allowance to 50 minutes per day.
Now, we did find it hard to fill 50 minutes x 2, even 50 minutes was stretching it a bit at times !
Then..............
Message 5 of 5
(426 Views)
- Home Phone
