1571 yet again.
FIXED- Subscribe to RSS Feed
- Home Phone
- Re: 1571 yet again.
31-12-2021 5:04 PM
I want 1571 voicemail disabled but it is not ticked as one of my Call features. Can you deactivate it as I do not require it and never signed up for it. Thanks
Fixed! Go to the fix.
Re: 1571 yet again.
31-12-2021 7:19 PM - edited 31-12-2021 7:21 PM
You can disable 1571 in the member centre.
https://community.plus.net/t5/Home-Phone/How-to-turn-OFF-1571/m-p/1223182#M18961
Try ticking and applying Voicemail, leave it 24 hours, then untick it.
Wait 24 hours and test.
Regards
Richard
Re: 1571 yet again.
31-12-2021 8:26 PM
Many thanks but, if it was that simple why did this happen ?
https://community.plus.net/t5/Home-Phone/disable-1571/td-p/1848236
Plus of course I would have no way of testing it.
I prefer to wait and get a member of Plusnet to permanent disable a facility that I neither asked for nor want.
02-01-2022 9:39 AM
Please accept our apologies for the inconvenience caused here @Djay
I've now placed the order to remove 1571 from your line, which should complete in a few hours, and will not be re-added unless you do so via your Member Centre.
Re: 1571 yet again.
04-01-2022 6:57 PM
Adam
Many thanks for your help.
Problem solved
DJay
Re: 1571 yet again.
05-01-2022 10:10 AM
Great stuff @Djay, thanks a lot for letting me know. Please feel free to reach out if you have any further issues at all. ![]()
