1571 answer machine removal
Jacbond
As with many other users I cannot remove the 1571 answer service, which is now overriding my own answer machine completely. It is not ticked as an option on my account and it would appear that the only way to have it removed is by asking for help here. Thanks in advance.
2 REPLIES 2
Longliner
All Star
Fixes: 8
Re: 1571 answer machine removal
Yes, you have to ask for its removal, agreed it's a nuisance if you have your own machine. Suggest you phone rather than waiting for a reply here as busy staff are sometimes slow to read the forum.
Mike
Fixes: 1,660
@Jacbond - the 1571 voicemail service should be gone for you within an hour.
[edit]
It's been removed now, let me know if there are any issues Smiley
