03xx Numbers
BlueEagle
03xx Numbers
Just checking..... Are ALL 03xx numbers included in the Anytime package or are some chargeable?
Thanks in advance.
12 REPLIES 12
petecov44
Re: 03xx Numbers
They are according to OFCOM - however someone got hit using the 03 PN support number so stick to 0800 for that.
BlueEagle
Re: 03xx Numbers
Quote from: petecov44
That's what go me thinking. Lots of companies are switching to these 03 prefix numbers rather than 0844/0845 but don't seem to make it clear what the call charges to them are. If my understanding is correct they are aimed at cutting out profit making/taking from necessary services (e.g. some companies making a profit on calls to their complaints department etc.).
I'm with GiffGaff for mobile so 0800 is free from that anyway, but wanted clarification from home phone on Anytime call plan.
HPsauce
Re: 03xx Numbers
I think it was outside their "free" time package (whatever that was), though there's a different issue as to whether it should have been free at any time irrespective of call package as it was a call to PN.
HairyMcbiker
All Star
Fixes: 21
Re: 03xx Numbers
Since my call package starts at 19:00 and the COT close at 17:30, what to do ?
But they are looking into the matter now.
petecov44
Re: 03xx Numbers
Yes I see your point however in their defence they have the 0800 number to use as well.
HairyMcbiker
All Star
Fixes: 21
Re: 03xx Numbers
But they CLEARLY state that calls to support are FREE from a PN line, not saying you MUST use the 0800 - which would be free ANYWAY.
HPsauce
Re: 03xx Numbers
Drifting well away from the original question here, isn't there a live separate thread already about support calls via these numbers?  Wink
Quote from: BlueEagle
The simple answer is yes, all are included.
petecov44
Re: 03xx Numbers
Unless you ring the mobile friendly 03 number - which is what started this all
pwatson
Re: 03xx Numbers
No, you're confusing the two issues!
The OP of this thread is specifically asking about the Anytime package - As calls to 03 numbers are/should be treated the same as calls to 01/02 numbers then they are covered by Anytime.
Hairy McBiker has rightly complained that he was charged for calling the 0330xxxxxx support number despite PN stating that all support calls are free.  From the comment above, I assume he has Evenings & Weekends in which case calls to 01/02/03 numbers are chargeable during the day.
LinnPlusnet
Re: 03xx Numbers
Quote from: Hairy
COT are open 09:00 - 20:00 Monday - Friday.
09:00 - 17:30 on Saturdays.
LinnPlusnet
Re: 03xx Numbers
Any calls made to numbers that start with 01, 02, or 03 are free (up to 60 minutes) with the Anytime call plan.
petecov44
Re: 03xx Numbers
Quote from: pwatson
Not confusing the issue - just didn't know about the E & W bit
Well my billing date was Monday I had my service installed yesterday - I can't change my call package until a month.. Sucks 😕
