best set up for PS3
- Gaming
- best set up for PS3
best set up for PS3
23-04-2009 11:28 PM
my question is this,
I have always manuly set up my IP address for my Ps3 and placed it in the DMZ of the router but are there any other settings for ps3 or router to enable me to get the best out of my new conection
cheers in advance for any replies
silver
Re: best set up for PS3
23-04-2009 11:36 PM
Use an ethernet cable to connect your PS3 to your router.
When you have switched and if your connection looks like it will be ok without it get interleaving switched off, help reduce your pings.
Other than that you should be good to go
24-04-2009 10:10 AM
Quote from: adiewoo Use an ethernet cable to connect your PS3 to your router.
Or if that isn't possible use Homeplugs.
I haven't got our PS3 in the Router's DMZ - I've just enabled UPnP and it works fine.
Bob
25-04-2009 10:57 AM
Quote from: adiewoo Hi and welcome to the forums.
Thanks for your replies,
Quick question about the above regarding interleaving what problems might this cause if switched off and will it make that much deference, at the moment with my old provider i get a ping of about 65ms to 75ms
also is it best to use the Thompson router supplied by plusnet or stick to the Belkin one i all ready use,
sorry to ask stupid questions
cheers silver
25-04-2009 12:29 PM
Can you post your router statistics so we can judge.
I'm sorry I have no experience of Belkin Routers so I can't really comment on the Belkin vs. Thompson question.
Bob
25-04-2009 6:35 PM
adie:quote
25-04-2009 7:38 PM
25-04-2009 10:05 PM
adie:quote
27-04-2009 12:48 PM
Quote from: silverstream
i mentioned earler i always put my ps3 in the DMZ of the router having just recevied the thompson router from plus net and having a quick look at it anyone know how to put the ps3 in DMZ on this one,
I can't seem to find an option for it,
No probs if you can't do this with the thompson ill just carry on using my Belkin one as it is already set up for my home network.
sorry again for asking more stupid questions
silver
27-04-2009 4:49 PM
http://community.plus.net/forum/index.php/topic,75917.16.html
27-04-2009 5:41 PM
