Xbox Live Help
- Gaming
- Xbox Live Help
Xbox Live Help
17-08-2009 12:45 PM
Hi , Probably a stupid question ..
Just got my plusnet pro broadband activated this morning but i cant sign in to xbox live
My xbox settings are on automatic and when i diagnose the problem it says
''Cant obtain ip address from router or modem''
Im using the Thomson TG585 v7 Router and have a static ip
Any help ?
Any help ?
2 REPLIES 2
Re: Xbox Live Help
17-08-2009 1:49 PM
Edit : It somehow worked when i turned the xbox on before my pc
Re: Xbox Live Help
17-08-2009 2:41 PM
your geting an ip conflict then.
check the lan setup options on the router and idealy set each mac address to obtain the same ips each time
