Traffic shaping only out going?
Gus
Lately been having issues with Lotro and after testing in some instances I have noticed that all Out going traffic is correctly prioritised as Gold/Titanium, but unless I am reading the packet captures wrong all incoming traffic is bronze which seems to be causing the good old rubber band lag or worse being stuck unable to move/do any actions.
So to PN, is the traffic management only Outgoing and not incoming and if so why?
ticket 40681530 for the capture in question
Unvalued customer since 2001 funding cheap internet for others / DSL/Fibre house move 24 month regrade from 8th May 2017
2 REPLIES 2
zubel
Re: Traffic shaping only out going?
It's more likely the reverse actually
Incoming traffic will have been classified by the Ellacoyas.  Outgoing traffic won't have passed through the Ellacoyas yet, so will appear to be unclassified.  This is expected behaviour
B.
bobpullen
Fixes: 258
Quote from: Gus
The outbound traffic you're sniffing hasn't been anywhere near our network so there's no way it can have had a ToS marking applied. Like Barry says, it's the inbound packets you need to be looking at. I often find it helps to lright click your IP in the destination field and apply a filter based on that. This removes all the outbound packets from view and saves any confusion.
