Starcraft 2 traffic priority.
- Gaming
- Re: Starcraft 2 traffic priority.
29-12-2010 7:48 PM
I am having some problems with SC2. This is not every game but enough to be annoying.
The game comes up with a message that says the game is waiting for me, sometimes I get dropped then other times I can play for a little bit with lag before I get dropped.
After looking at a wireshark capture of a game that did not drop me. I noticed not all my traffic was titanium some of it was gold. Could this be what is causing the problem?
In the mean time I will try and get a wireshark capture of a game where I get dropped.
2 REPLIES 2
30-12-2010 9:14 AM
Quote from: Oxslow In the mean time I will try and get a wireshark capture of a game where I get dropped.
If you can that would be very helpful. If it's getting misclassified then we can raise a Change Control to have things corrected.
31-12-2010 10:44 PM
I got dropped from a game tonight here is the router stats and a wireshark capture
adslctl: ADSL driver and PHY status
Status: ShowtimeRetrain Reason: 8000
Channel: FAST, Upstream rate = 800 Kbps, Downstream rate = 4831 Kbps
Link Power State: L0
Mode: ADSL2
Channel: Fast
Trellis: U:ON /D:ON
Line Status: No Defect
Training Status: Showtime
Down Up
SNR (dB): 3.2 5.8
Attn(dB): 49.5 29.0
Pwr(dBm): 0.0 12.8
Max(Kbps): 5400 788
Rate (Kbps): 4831 800
G.dmt framing
K: 148(0) 101
R: 4 16
S: 1 1
😧 64 8
ADSL2 framing
MSGc: 60 12
B: 147 100
M: 1 1
T: 1 1
R: 4 16
S: 0.9735 4.0000
L: 1249 234
😧 64 8
Counters
SF: 11444864 10213945
SFErr(CRCErr): 732 0
RS: 755361044 3462383
RSCorr: 555836 10
RSUnCorr: 8138 0
HEC: 543 0
OCD: 1 0
LCD: 0 0
Total Cells: 2095047215 1527369
Data Cells: 65254756 12401
Drop Cells: 0
Bit Errors: 0 0
ES: 10258 0
SES: 40 2
UAS: 154 0
AS(Uptime): 183852
INP: 0.81 2.18
PER: 16.06 18.00
delay: 15.57 8.00
OR: 32.86 8.00
Bitswap: 17245 331
Total uptime: 967106
Total time = 1 days 4 hours 42 min 25 sec
SF = 60046881
CRC = 26796
LOS = 0
LOF = 0
ES = 10258
Latest 1 day time = 4 hours 42 min 25 sec
SF = 1054883
CRC = 78
LOS = 0
LOF = 0
ES = 52
Latest 15 minutes time = 12 min 25 sec
SF = 46391
CRC = 3
LOS = 0
LOF = 0
ES = 2
Previous 15 minutes time = 15 min 0 sec
SF = 56069
CRC = 2
LOS = 0
LOF = 0
ES = 1
Previous 1 day time = 24 hours 0 sec
SF = 5378433
CRC = 361
LOS = 0
LOF = 0
ES = 189
15 minutes interval [-30 min to -15 min] time = 15 min 0 sec
SF = 56007
CRC = 3
LOS = 0
LOF = 0
ES = 2
15 minutes interval [-45 min to -30 min] time = 15 min 0 sec
SF = 56006
CRC = 9
LOS = 0
LOF = 0
ES = 5
15 minutes interval [-60 min to -45 min] time = 15 min 0 sec
SF = 56069
CRC = 0
LOS = 0
LOF = 0
ES = 0
Showtime Drop Reason: 8000
Last Retrain Reason: 8000
http://www.oxslow.plus.com/dropped_sc2.pcap
Mode: ADSL2
Channel: Fast
Trellis: U:ON /D:ON
Down Up
SNR (dB): 3.2 5.8
Attn(dB): 49.5 29.0
Pwr(dBm): 0.0 12.8
Max(Kbps): 5400 788
G.dmt framing
K: 148(0) 101
R: 4 16
S: 1 1
😧 64 8
ADSL2 framing
MSGc: 60 12
B: 147 100
M: 1 1
T: 1 1
R: 4 16
S: 0.9735 4.0000
L: 1249 234
😧 64 8
Counters
RSCorr: 555836 10
RSUnCorr: 8138 0
HEC: 543 0
OCD: 1 0
LCD: 0 0
Drop Cells: 0
Bit Errors: 0 0
ES: 10258 0
SES: 40 2
UAS: 154 0
AS(Uptime): 183852
INP: 0.81 2.18
PER: 16.06 18.00
delay: 15.57 8.00
OR: 32.86 8.00
Bitswap: 17245 331
SF = 60046881
CRC = 26796
LOS = 0
LOF = 0
ES = 10258
SF = 1054883
CRC = 78
LOS = 0
LOF = 0
ES = 52
SF = 46391
CRC = 3
LOS = 0
LOF = 0
ES = 2
SF = 56069
CRC = 2
LOS = 0
LOF = 0
ES = 1
SF = 5378433
CRC = 361
LOS = 0
LOF = 0
ES = 189
SF = 56007
CRC = 3
LOS = 0
LOF = 0
ES = 2
SF = 56006
CRC = 9
LOS = 0
LOF = 0
ES = 5
SF = 56069
CRC = 0
LOS = 0
LOF = 0
ES = 0
