Problems with online games
drweir4
Hi there, i am a loyal plus net customrer but i am getting extremeley frustrated with constant drop outs in online games. I seem to randomly lose connection when playing BF3 and Wargame on steam, and occasionally on Company of Heroes. The internet connection itself doesnt drop but i lose connection to the game.
Please help
6 REPLIES 6
Kelly
Fixes: 9
Re: Problems with online games
All the time?  Or just tonight?
Kelly Dorset
Ex-Broadband Service Manager
drweir4
It has been an intermittent problem, but yes, it has specifically happened tonight
Strangely it seemed to be working at around 5.30, but now since 8.00 the same game has repeatedly had this problem of randomly dropping me
Fixes: 1,483
Which platform are you playing on?
Kelly
Fixes: 9
Have you tried a reboot?  We've got some congested gateway tonights which might be causing problems.
Kelly Dorset
rongtw
Fixes: 12
i had similar problems , if its PC gaming best thing to do is to disable UPNP  in the router  Wink
orbrey
It looks like you might only be turning on the router when you're using the connection? I'd recommend keeping it on all the time if that's possible, just to see if that does improve things for you.
