Port Forwarding
robhw
Port Forwarding
I have read through a few posts about this and done what i think is correct, below is what I have done however, when I test the port it still saying it is closed. Please help, I'm trying to Host a private game server for my friends to connect to.
The first picture is the games IP and Port number assigned to it. the other screens are all the Hub options showing I have done what I Think is correct to get the port open. The last Picture (Port forwarding tester) from https://www.yougetsignal.com/tools/open-ports/ shows that the port is not open so I must of done something wrong.
14 REPLIES 14
Fixes: 1,495
Re: Port Forwarding
Can you connect to the server on your local lan?
It looks like you've configured the game and not the server in the first screenshot.
Fixes: 147
Re: Port Forwarding
Hi @robhw
The first screen shot.
Why are you using the loopback IP or is that correct?
The Port number shows 7.100 shouldn't it be 7100?
As @dvorak says can you connect to the server on the local lan?
Dan
Fixes: 1,495
Re: Port Forwarding
If the server was on the localhost then I guess that would be correct?
but I think we've only seen the game config and not the server config
robhw
Re: Port Forwarding
Yeah, If I put the local lab in that part where it says 127.0.0.1 it doesn’t work. I configured the server too, I just haven’t put that screen shot up.
robhw
Re: Port Forwarding
From the guides I seen this is the correct way to set the game config up, I have set the server up too, just haven’t included the screen shot of it.
It’s not clear in the picture but that is a comma, to make it 7100 (auto puts it in).
I can connect myself as it is, if I change anything to my local IP or external IP it doesn’t connect
Fixes: 1,495
Re: Port Forwarding
have you opened up the ports on your windows(?) firewall?
Fixes: 147
Re: Port Forwarding
@robhw
When you connect locally are you using the same PC as the server is running on? This could be why you can connect the loop back IP 127.0.0.1 only. You need to try connecting to the server from a second device to test correctly.
You would not use the external IP address as the port forwarding rules does the mapping for outside connections.
Dan.
robhw
Re: Port Forwarding
my brother has tried connecting from his home onto the server and it inst allowing him on, just keeps saying attempting to connect - he is inputting my external IP address on the game config shown on original post.
attached to this post is the server config requested and also the windows firewall port 7100 access.
Fixes: 1,495
Re: Port Forwarding
As Dan says you need to try and connect to the server on your local network from a different machine first to make sure that your server is working correctly.
robhw
Re: Port Forwarding
I don’t have a second one in my home.
Fixes: 147
Re: Port Forwarding
@robhw
So my understanding is unless you configure 127.0.0.1 on the server you are unable to connect locally.
What could be happening is the server will only accept a local loopback IP address, a connection from the same pc.
Try replacing 127.0.0.1 with 0.0.0.0 this might allow connections from any IP address.
Try locally then from external connection.
Dan.
robhw
Re: Port Forwarding
With 0.0.0.0 on server config I can still connect using the same PC on the game client. I will ask my brother to re try getting on using my external IP address.
robhw
Re: Port Forwarding
Surely if sites are telling me the port 7100 is closed then no one externally can use it?
Fixes: 147
Re: Port Forwarding
does https://www.canyouseeme.org/ still tell you port 7100 is closed?
On you server using a command prompt
c:\netstat -an | findstr 7100
what is the output text?
Dan
