Ongoing World of Warcraft issues
- Gaming
- Ongoing World of Warcraft issues
Re: Ongoing World of Warcraft issues
09-09-2019 7:55 PM
Thank you so much. It was happening all evening so I will provide an update on how things go from now a bit later!
09-09-2019 8:43 PM
@JonoH wrote:Is it WOW Classic you're playing? if it is they have been victims of sustained DDOS attacks and I myself have experienced instance not found on both my Plusnet and None Plusnet connections.
Yep it was wow classic I had the issues on last week. Haven't been able to play retail unfortunately due to the lack of people on it at the moment.
09-09-2019 11:54 PM - edited 09-09-2019 11:56 PM
Sounds good. Oh and for the Horde!
Unless you play as the Alliance, in which case I’ll grudgingly replace the word Horde with Alliance.
Fingers crossed things have gone well though!
10-09-2019 8:57 AM
Are retail populations really that bad?
10-09-2019 2:58 PM
@JonoH put it this way...on retail im in a guild of 979 people, currently there are 2 other people online ![]()
10-09-2019 3:41 PM
10-09-2019 7:41 PM
It seems the static IP has solved the problem for me. I have been running instances none stop (constant loading screens) and have not had a single freeze/disconnect/world server error since. The hour before you guys did the IP change I was running into those issues on about 2/3 of loading screens.
As soon as you made the change for me it has not happened a single time! ![]()
I understand a static IP may not be the permanent fix you can offer and I'm happy to help you diagnose further if there is anything I can do on my end.
I don't normally associate with Horde.. but you guys OK
13-09-2019 4:13 PM
Hi, I can confirm that this is an issue for Classic as well, it's been driving me nuts.
This also has nothing to do with the DDoS - I've observed it regularly before, during, and after the attacks.
I went through the entire thread and it seems that a static IP would fix this - can I get one as well? Will this show up on our bill? It's not really about the £5, but I'd have to explain it to our landlord etc. ![]()
For what it's worth, I think this behaviour is completely unacceptable on Blizzard's part. The game should (and mostly is) be resilient even to 2-3 sec complete outages; some packet loss shouldn't throw you off the flight path midway, it's completely game braking
Thanks for helping with this!
14-09-2019 12:48 PM
Awesomeness, it's good to see that you've been able to play normally since having a static IP. ![]()
Thanks for being our guinea pig, we'll be in touch soon to get started if we need to.
Lok'tar ogar!
@iosifs Sorry to see you're having issues too
Log into your account then go Here to add a static IP on. Once it's added you'll need to reboot your router/disconnect your connection for it to take effect. While this will add a one off charge of £5 onto the next bill, if you don't want to keep the static IP indefinitely I'd be happy to add a credit of £5 to negate it. I'll then remove the static IP along with the free ones we've added once we're sure that we're not the cause for the issue.
Let us know how it goes, it's not a guaranteed fix as there may be other causes but if it doesn't fix the problem and you don't want to keep the static I'll get the credit added and the IP removed. Fingers crossed it improves things though!
14-09-2019 3:20 PM
For me it's beginning again...
Looking forward to playing some classic
16-09-2019 10:19 AM
I hope you chose Shazzrah @Gandalf
16-09-2019 1:47 PM
@JonoH Unfortunately I had a momentary lapse of judgement and went for a non-pvp realm Mirage Raceway. Currently level 8 Tauren Hunter, my plan was to transfer to a pvp realm when I'm high enough.
Reading up, don't think it's possible to go from normal/pve to pvp but the other way round seems do-able.
Ah well. Might make an alt character on Shazzrah.
16-09-2019 2:02 PM
@Gandalf Nothing wrong with mirage raceway...unless you're horde ![]()
16-09-2019 2:05 PM
When you do let me know your char name and leveling zones
16-09-2019 3:51 PM
Yup will do.
Watching the The Two Towers while levelling up, this is what days off are made for.
