AGAR.IO Game - Recaptcha Robot Check Appearing all the Time
Sxxxx24
Hi I play an online game called Agar.io, since the 29th November every time I enter a server I get asked to the ReCaptcha robot check, I have to do this EVERY time I try to spawn in the server. This also happened to me on around the 16th/17th October, which lasted for around a week then the game started working as normal - I did not do anything to fix this problem.
I have cleared cache, cookies, history etc, changed browsers, deleted+reinstalled browsers, tried different log-in's (FB, Google, guest), changed my IP, did system restore, removed all potential malware, disabled extensions, tried VPN's, disconnected+reconnected to Internet, restarted router, but none of these have worked.
I have tested another laptop and it also gets the ReCaptcha aswell.
Does anyone know what the problem is and how I can fix it?
Also to add when I emailed Miniclip the owner of Agar.io, they said
"According to our team, if our system detects some automated request from your system/network the recaptcha will always show."
Moderator's note by Dick (Strat): All caps title/text edited as per Forum rules.
9 REPLIES 9
Fixes: 1,662
Re: AGAR.IO Game - Recaptcha Robot Check Appearing all the Time
This is probably a long shot, but what happens if you switch off your router's firewall or create a port forwarding rule by going here then navigate to the Advanced Settings > Firewall tab.
Sxxxx24
Game has randomly started working fine for no reason earlier today. Grin
Fixes: 1,662
Ah cool, that's good to hear. Thumbs_Up
Sxxxx24
As of 10th January the problem has started again
Kelly
Fixes: 9
Just to be clear, was it working on the 8th and 9th?
Kelly Dorset
Ex-Plusnet Jobsbody
Sxxxx24
Hi I didn’t play it on the 8th but I assume it was working. I played it on Wednesday the 9th just after midnight and it was working fine
Kelly
Fixes: 9
Your account has changed IPs ranges a little, but they don't match up with when you were seeing issues so I don't think it's related.  Are any other players seeing anything similar?  (I just had a play. Odd game!)
Kelly Dorset
Ex-Plusnet Jobsbody
Sxxxx24
The latest Rcaptcha problem fixed on the 16th. And no I’ve spoken to many other players about it, they just have the occasional robot checks which is normal, but I’ve not heard of anyone having the same problem as me
UnRealm
I also have captcha problem, I've just use clone agario. There is no captcha.
http://agario-game.space/
