Ongoing World of Warcraft issues
Nichelledewell
Re: Ongoing World of Warcraft issues
 @Gandalf by any chance has my static ip been removed because all day its gone back to transfer aborted and world server down like it was before its driving me crazy ! Sad
Kelly
Fixes: 9
@Nichelledewell The statics have been removed a while.  When did you start seeing problems again?
Kelly Dorset
Ex-Plusnet Jobsbody
skunknste
I too had the instance aborted message appear today, only the once though.  Its been working great for a few weeks now with no issues, hope it's not coming back.
Killkenny
Yup, I'm afraid I'm having the same issues again too. World Server down and Instance errors.
samwalton
I'm also currently getting word server is down issues Sad
Kelly
Fixes: 9
@Killkenny I just reapplied your static IP.  Can you reboot your router and let me know if that's fixed it?
Kelly Dorset
Ex-Plusnet Jobsbody
Kelly
Fixes: 9
Added yours again.  Please reboot your router and let us know if that's better?
Kelly Dorset
Ex-Plusnet Jobsbody
Kelly
Fixes: 9
How is your gaming tonight?
Kelly Dorset
Ex-Plusnet Jobsbody
Nichelledewell
sorry for the late reply i experienced these issues today when i first started playing its been unplayable since i last spoke i have not played im going on to try agian now, just starting to get a bit fed up now if this is just plus net just want to be able to play my game
Kelly
Fixes: 9
@Nichelledewell wrote:
I've just giving you a static again, so please restart your router and let us know if that's any better.
Kelly Dorset
Ex-Plusnet Jobsbody
Nichelledewell
ok thank you very much, the only thing im worried about is how long does the static ip last ? is this issue still getting looked into your end ? cause this seems like alot of hassle coming on re applying a static ip everytime it doesnt work
Nichelle
Kelly
Fixes: 9
Hi, it will stay on until we remove it.  We removed them last week because we believed the issue was resolved.
Really sorry the issue has come back again.
Kelly Dorset
Ex-Plusnet Jobsbody
Nichelledewell
ok thats fine hopefully this static ip will work fine agian till the problems sorted thank you for your help agian
Killkenny
@Kelly, Thanks mate. That seems to have fixed it.
Having said that, rebooting the router seemed to help before. I'll let you know if the problem comes back again.
rincewind81
Hello,
Could I please have the static IP re-applied, the 'Transfer Aborted Instance Not Found' Error is re-occurring frequently again.
Thanks,
