Newbie to Plusnet, advice please?
Fixes: 1,485
Re: Newbie to Plusnet, advice please?
Well it does look like uTorrent has been used is it just your mac on the network?
WPA-PSK is fine for your security, though you might consider changing your password.
Denevenom
plus my wife's laptop (pc)
should i close the torrent in the router?
Fixes: 1,485
well looks like someone has set up a port forward for it so it might well be worth deleting.
Definitely change your password, make sure uTorrent isn't installed on your wife's lappy.
scootie
if you utorrent is uploading every time your wife uses her laptop then that would account for the usage?
asbo wonders if your son knows a thing or 2 about pc's an routers  Wink
Fixes: 1,485
also consider changing the password for your router
Denevenom
something is going on - I used a bandwidth monitor which shows at 18:36 there was 145.6mb down and 34.1mb up, now its showing 151.3mb down and 38.2mb up and all i have done is use this website - wife's lappy and xbox turned off!
Fixes: 1,485
what does your router show under attached devices?
scootie
i would surrgest using net limiter 2 freeware http://www.netlimiter.com/download.php to see which apps are using what bandwidth usage but i dont think there is mac version.
but have look for a monitor that spilts the usage bettween apps runing on the mac
Denevenom
when i try to delete the torrent doofer at the the router it is saying:
This service is used by the rules function, you can not edit/delete it! Please delete corresponding rules first.
what rule?????????????
Denevenom
# IP Address Device Name MAC Address
1 192.168.0.2 MAC001F5BEE3A96 00:1E:C2:C0:F5:36
Fixes: 1,485
there is an option called 'firewall rules' on the right hand navigation, it'll be under there.
Fixes: 1,485
so it does seem that your mac is the only thing online, though it isn't 100% accurate... there is a utorrent client for mac but it's in beta so I'm sure you'd know if you'd got that installed.
Denevenom
does this look correct?
# Enable Service Name Action LAN Server IP address WAN Users Log
1 DNS ALLOW always 192.168.0.7 192.168.0.7 Always
2 Xbox3 ALLOW always 192.168.0.7 192.168.0.7 Always
3 Xbox2 ALLOW always 192.168.0.7 192.168.0.7 Always
4 Xbox1 ALLOW always 192.168.0.7 192.168.0.7 Always
5 uTorrent ALLOW always 192.168.0.11 Any Always
Default Yes Any BLOCK always Any Any Never
Fixes: 1,485
change uTorrent to BLOCK always.. see if that makes a difference.
Denevenom
oops I deleted it, is that ok?
