Newbie to Plusnet, advice please?
- Gaming
- Newbie to Plusnet, advice please?
- « Previous
- Next »
Re: Newbie to Plusnet, advice please?
03-07-2009 8:05 PM
03-07-2009 8:07 PM
Turn UPnP On
Advertisement Period (in minutes)
Advertisement Time To Live (in hops)
UPnP Portmap Table
Active Protocol Int. Port Ext. Port IP Address
YES UDP 3074 3074 192.168.0.3
03-07-2009 8:11 PM
03-07-2009 8:19 PM
thanks for all your help guys btw
03-07-2009 8:37 PM
You have to make sure the dmz ip is allways given to the ps3 tho as it will be sercuity risk if done to a pc
03-07-2009 8:49 PM
03-07-2009 8:53 PM
03-07-2009 9:10 PM
so on the xbox then what's best? port forwarding? can you talk me through how?
03-07-2009 9:40 PM
WIth the PS3 on go to attached devices, work out which is your ps3 and copy the mac address and the IP address.
Go into LAN IP setup and for address reservation add your ps3 details
Then under WAN setup click enable and add the reserved IP address for your PS3
should be it
04-07-2009 7:37 AM
Switching on the Surf option to block some P2P apps https://portal.plus.net/surf/ and also switching your BB firewall to high here https://portal.plus.net/my.html?action=firewall&firewallPage=basic, won't stop P2P as such but might help block some incoming traffic.
04-07-2009 11:32 AM
06-07-2009 12:31 AM
- « Previous
- Next »
