Newbie Interleaving question
- Gaming
- Newbie Interleaving question
20-11-2009 4:28 PM
My ticket reference number is-30847373.
Re: Newbie Interleaving question
20-11-2009 4:34 PM
20-11-2009 4:38 PM
20-11-2009 5:06 PM
Version Info
Firmware Version 6.01.06 (Jun 7 2006 20:25:29)
Not sure what all that means but says nothing about interleaving.
20-11-2009 5:08 PM
![Wink Wink](/html/@ED8EAB3707DE077FFF94EEBAB958E3C6/images/emoticons/wink.gif)
your looking for this sort of stats http://www.digitalspy.co.uk/forums/showthread.php?p=28250817
also is that 2006 firmare the latest for your router, ive looked on the belkin site to check but couldnt find your model in the support list
20-11-2009 5:32 PM
20-11-2009 5:38 PM
20-11-2009 7:18 PM
ADSL Status Information
Status: Status
Configured
Current
Line Status
SHOWTIME
Link Type
Interleaved Path
Date Rate: Data Rate
Stream Type
Actual Data Rate
Up Stream
448 (Kbps.)
Down Stream
8128 (Kbps.)
Operation Data / Defect Indication: Operation Data
Operation Data
Upstream
Downstream
Noise Margin
27 dB
9 dB
Attenuation
2 dB
4 dB
Defect Indication
Indicator Name
Near End Indicator
Far End Indicator
Fast Path FEC Correction
0
0
Interleaved Path FEC Correction
2244
8588
Fast Path CRC Error
0
0
Interleaved Path CRC Error
6
11
Loss of Signal Defect
0
Fast Path HEC Error
0
0
Interleaved Path HEC Error
408
0
Statistics: Statistics
Received Cells
6486295
Transmitted Cells
1791862
I think this is the stats i want, don't know what it all means though!
![Embarrassed Embarrassed](/html/@6CEFBAD878A40FF337662307A879A7FD/images/emoticons/embarrassed.gif)
20-11-2009 8:39 PM
Quote Link Type
Interleaved Path
that will change to fastpath or interleave depth 1 but most likely fastpath. there the same either way
and the fastpath hec an crc counts will start to clock errors and the interleaved ones wont.
with an atten of 4db u shouldnt get any or many errors thoe. at a guess you can touch the exchange form where your sat now
![Grin Grin](/html/@D40767E4EBB99989487344F3E42E44B1/images/emoticons/grin.gif)
20-11-2009 11:05 PM
![Smiley Smiley](/html/@39650D28FE4EA73A5BA77CFD0A477003/images/emoticons/smiley.gif)
20-11-2009 11:26 PM
21-11-2009 12:09 AM
Re:Newbie Interleaving question
23-11-2009 1:27 PM
23-11-2009 1:34 PM
23-11-2009 5:56 PM
Status: Status
Configured
Current
Line Status
SHOWTIME
Link Type
Fast Path
Stream Type
Actual Data Rate
Up Stream
448 (Kbps.)
Down Stream
8128 (Kbps.)
Operation Data
Upstream
Downstream
Noise Margin
27 dB
8 dB
Attenuation
2 dB
4 dB
Defect Indication
Indicator Name
Near End Indicator
Far End Indicator
9
0
0
0
Fast Path CRC Error
26
51
0
0
0
Fast Path HEC Error
0
0
0
0
Received Cells
7640137
Transmitted Cells
1586025
it looks as though its been switched over now don't know what all the stats mean but i will try online gaming tonight, thanks for all the help guys.
