Newbie Interleaving question
- Gaming
- Newbie Interleaving question
- « Previous
- 1
- 2
- Next »
Re: Newbie Interleaving question
23-11-2009 6:09 PM
cant tell how long those stats are for but that amount of crc errors is fine either way.
what do you get when you do a command prompt traceroute to bbc.co.uk.
command to use, "tracert bbc.co.uk"
below my fastpath error stats for a 27day long connection, the upstream errors are a bug thats why there higher than the actual SF count
23-11-2009 6:15 PM
Just done a speed test, am getting 6500 download and 380 upload at 6.00p.m.
I did a ping test with pingtest.net and got a ping of 26ms and jitter if 1ms which sounds good but the thing i am concerned about is is i am getting a Packet Loss of 96%, again i am unsure of what this means do any of you guys know? During the test it sends 250 packets and only 10 are recieved which gives me the 96% loss and an F rating.
Will do the BBC thing now.
23-11-2009 7:26 PM
Done bbc test but cannot save the results! i have tryed everything,i've even took a pic of them and cannot attach them to this message, i'll keep trying!
23-11-2009 7:29 PM
also try a command prompt ping test, "ping -t bbc.co.uk" and "crtl+c" to stop it. this will give you an idea of packet loss.
i ask for you try that method as we dont tend to trust speedtestnet / pingtestnet
right click the top bar of cmd pmt and go to propities and check quickedit, then you can highlight the text in the normal manner and right click the top bar and select edit, copy then paste here
23-11-2009 7:54 PM
finally copied first test-
Tracing route to bbc.co.uk [212.58.224.138]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms . [192.168.2.1]
2 27 ms 71 ms 60 ms lo0-plusnet.ptn-ag1.plus.net [195.166.128.123]
3 28 ms 29 ms 26 ms gi2-2-303.ptn-gw01.plus.net [84.92.3.9]
4 27 ms 25 ms 27 ms te2-2.thn-gw1.plus.net [212.159.1.54]
5 29 ms 27 ms 31 ms te2-3.thn-gw2.plus.net [212.159.1.58]
6 29 ms 29 ms 42 ms rt0.thdo.bbc.co.uk [212.58.239.25]
7 25 ms 25 ms 39 ms 212.58.238.149
8
2 60 ms 25 ms 64 ms lo0-plusnet.ptn-ag1.plus.net [195.166.128.123]
3 27 ms 30 ms 27 ms gi2-2-303.ptn-gw01.plus.net [84.92.3.9]
4 26 ms 30 ms 27 ms te2-2.thn-gw1.plus.net [212.159.1.54]
5 34 ms 30 ms 33 ms te2-3.thn-gw2.plus.net [212.159.1.58]
6 153 ms 221 ms 228 ms rt0.thdo.bbc.co.uk [212.58.239.25]
7 33 ms 29 ms 44 ms 212.58.238.149
8
2 50 ms 70 ms 28 ms lo0-plusnet.ptn-ag1.plus.net [195.166.128.123]
3 27 ms 41 ms 25 ms gi2-2-303.ptn-gw01.plus.net [84.92.3.9]
4 134 ms 198 ms 45 ms te2-2.thn-gw1.plus.net [212.159.1.54]
5 29 ms 26 ms 49 ms te2-3.thn-gw2.plus.net [212.159.1.58]
6 134 ms 175 ms 213 ms rt0.thdo.bbc.co.uk [212.58.239.25]
7 29 ms 37 ms 28 ms 212.58.238.149
8
2 32 ms 29 ms 33 ms lo0-plusnet.ptn-ag1.plus.net [195.166.128.123]
3 174 ms 219 ms 191 ms gi2-2-303.ptn-gw01.plus.net [84.92.3.9]
4 29 ms 32 ms 30 ms te2-2.thn-gw1.plus.net [212.159.1.54]
5 29 ms 56 ms 30 ms te2-3.thn-gw2.plus.net [212.159.1.58]
6 37 ms 32 ms 28 ms rt0.thdo.bbc.co.uk [212.58.239.25]
7 36 ms 45 ms 29 ms 212.58.238.149
8
will do other one now
wil
8
8
8
8
wil
23-11-2009 7:59 PM
ping test-
Pinging bbc.co.uk [212.58.224.138] with 32 bytes of data:
Reply from 212.58.224.138: bytes=32 time=25ms TTL=120
Reply from 212.58.224.138: bytes=32 time=31ms TTL=120
Reply from 212.58.224.138: bytes=32 time=26ms TTL=120
Reply from 212.58.224.138: bytes=32 time=28ms TTL=120
Reply from 212.58.224.138: bytes=32 time=35ms TTL=120
Reply from 212.58.224.138: bytes=32 time=29ms TTL=120
Reply from 212.58.224.138: bytes=32 time=27ms TTL=120
Reply from 212.58.224.138: bytes=32 time=45ms TTL=120
Reply from 212.58.224.138: bytes=32 time=24ms TTL=120
Reply from 212.58.224.138: bytes=32 time=32ms TTL=120
Reply from 212.58.224.138: bytes=32 time=80ms TTL=120
Reply from 212.58.224.138: bytes=32 time=47ms TTL=120
Reply from 212.58.224.138: bytes=32 time=30ms TTL=120
Reply from 212.58.224.138: bytes=32 time=43ms TTL=120
Does this look o.k?
Does this look o.k?
- « Previous
- 1
- 2
- Next »
