Extremely high ping on rust?
Glassy13
Re: Extremely high ping on rust?
They  apparently fixed this issue this morning around 9am however im still affected! Sad
Bouncer
Same here, Issue was apparently fixed but my lag spike is now as high as 15000ms via the rust console, That's double what it was before the fix!
Spoke to someone at PlusNet who knows what they are talking about, The issue that was marked as "solved" is still affecting about 15,000 customers. If your IP starts 14x. you are on the equipment that is [-Censored-]ed. I asked for a static IP and it solved my issue instantly.
Also noticed that PlusNet has Rust tagged as an Interactive service so it has "gold priority" not the Titanium it should have
LucageArts
Just checked now and my IP starts with 192.
Jumped on a server and I'm still getting bad lag spikes and disconnects.
Glassy13
Just changed my ip to static and my ip starts with 19x. This has stopped me going above 5000ms but still not able to play what so ever. Also ran me down £5 for the static ip...
Bouncer
What sort of ping are you getting in the rust console? What sort of issue are you getting that is making it unplayable?
Glassy13
Ill get 50 ping for like 3 seconds then it would spike to 1000 for a few seconds then 3000 for a few then slowly drop back down, back down to 50 and then it would repeat. Therefore i am constantly lagging/rubber banding and making it impossible to open doors/mine resources. I have tried PVP and my enemies are stuttering everywhere.
Bouncer
When I called last night they guy spoke to someone and said the equipment Server Stack (possibly Access rack) starting 213 is what is causing issues I asked for a static IP with was assigned from Server stack 195.
Before I done all this I also discovered. Atleast with the server I am using Plusnet has it marked as an interactive service and not as as Online Gaming & VoIP.
Perhaps that is giving you issues.
There is a (empty) server called Hot Feet Forever you'll find me on there at the momment if you want to test any ideas.
bobpullen
Fixes: 330
We're still looking into issues causing packet loss.
LucageArts
Glad to hear it Bob. Smiley
LucageArts
Was thinking about giving Rust another go tonight. Has this issue been resolved now? Smiley
jaread83
Fixes: 81
There have been reports of users seeing an improvement since Friday last week after a tweet stating that a fix has been implemented. Worth giving it another shot Smiley
LucageArts
Great news! Look forward to try it out again. Thanks!
Kelly
Fixes: 9
Any update?   Working better now?
Kelly Dorset
Ex-Plusnet Jobsbody
LucageArts
I've only been on low pop servers so far, so not sure how much of a difference that makes.
I will try a high pop one as soon as I can and will let you know.
LucageArts
Played in an event on the weekend with a decent amount of players on Rust. Everything was hunky dory.
