Connect Xbox one
de8813
Connect Xbox one
Hi there I am trying to connect my son's Xbox one to the internet. Whilst it is finding our plusnet account it cannot connect and is saying it cannot connect to the DHCP Server.
Our router is not going through a PC. We don't have one just now, we simply plugged it in and connected our phone via WiFi.
Really need to connect the xbox before Christmas. Can anyone help please.
9 REPLIES 9
Fixes: 1,495
Re: Connect Xbox one
welcome to the forums Smiley
are you connecting via a wire or wireless?
de8813
Hi there thanks for the response, it's a wireless connection we are looking to establish.
My sister downloaded some items to it when it was first purchased so I think it may still have her network details on it
Purley based on the grounds that it has wired connection details on it. Maybe these details come up when it gets to connect to our network? I am a complete novice at this..
Fixes: 1,495
If you haven't entered the settings for your wifi you'll need to do that:
  • Turn on your Xbox One and go to the Settings menu.
  • Select Network.
  • Select Set Up wireless network, to connect to a new network.
  • Xbox One asks Which one is yours? and displays the wireless networks it detects in your area.
  • Select the network you want to connect to.
  • Press the Enter button on your controller.
  • Xbox One connects to the network you select, using the password you provided.
Then, it checks whether it can connect to the Internet. If all is well, Xbox One informs you that your console is now connected to the Internet.
  • Press Continue to get back to the Network Settings.
  • Press the Home button on your controller.
You are now connected to the new wireless network you have selected.
de8813
Hi and thank you again. Yes, I have got to this stag but it cannot connect. It says cannot connect to DHTP server?
Fixes: 1,495
Sorry I don't have an XBOX (we're a playstation house Smiley ) so I'm just looking around for you.
There's a video here with some steps, first of which is to switch everything off including your router. https://www.youtube.com/watch?v=wwkQ8U5HiRQ
de8813
Thank you I will check this out when I get home. When u say enter setting GS what setting do you mean and where are they found please.
I didn't do this as far as I know, I thought the network chosen put them on.
Fixes: 1,495
it's just following those steps to make sure that you've tried it with your wireless network and it's not trying to use your sisters still.
de8813
Sorted! Thank you.
Merry Christmas to you and yours ⛄
Fixes: 1,495
Glad it's sorted for you Smiley
Merry Christmas
