Dolphin netplay lag
Peterdas1
Dolphin netplay lag
So I portforwarded to play dolphin netplay online but it lags even though the ping is stable and my PC can run it fine, any help?
7 REPLIES 7
ghos7
Re: Dolphin netplay lag
are you using plusnet hub?
Peterdas1
No I'm using a 582n router
Moderator's note by Mike (Mav): Full quote of preceding post removed as per Forum rules.
ghos7
i think that router as upnp extended security. it plays havoc with games. try disabling it.
Peterdas1
Okay I'll try that thanks for your help
Peterdas1
So I don't want upnp and extended security on when I play?
ghos7
you want upnp on but upnp security off.
Peterdas1
No didn't work
