Deus Ex Human Revolution
- Gaming
- Deus Ex Human Revolution
25-08-2011 10:56 AM
Of course the next thing is whether my rig will even run it properly or whether I should upgrade my CPU or graphics card - certainly not both
System is CPU E6750 GPU 8800GT
Re: Deus Ex Human Revolution
25-08-2011 5:00 PM
so if i was you UPGRADE m8
Plenty of sites around to grab a bargain from Aria PC, http://www.aria.co.uk/, Scan ,http://www.scan.co.uk/, or my local shop ,http://www.cclonline.com/.
spend some of ya pension money like i did and end up with like mine
Amd 4 core 3.1gig cpu
4 gig ddr2 ram
2 x 1gig ati 6870 Gpu
ooops i can play just about any game around , but waiting for BF3
25-08-2011 5:06 PM
and it won't even run Elite
Just to add - I don't buy computers I build my own and with my current rig the best upgrade short of changing the motherboard and memory is a top of the range Intel Core 2 quad (about £250) and a flaming expensive Nvidia graphics card (SLI won't work as the motherboard doesn't support 2 PCIE x16 cards)
More realistically I can move it up to the next level for about £220 but I am not sure it is worth it with a 1680 x 1050 monitor - will wait and see how it runs
26-08-2011 8:15 AM
shop around and find the bits you want and get a good deal.
ps i have a 26" iiyama 1080p running at 1920 x 1080
everyone say,s i am to old for gaming
26-08-2011 10:40 AM
I'm currently running an E8500 (well, the Xeon equivalent, not sure what the model number is but essentially it's exactly the same chip) with an nvidia GTX 460 and it plays everything I've got at 1680x1050 (I do have an 8800GTX in there doing physX but as you have an 8800GT you could do exactly the same with that). Quick check on ebay shows E8500's going for around £80 on buy it now and you could pick up a 460 for around £120? You only really need a better card than that if you're using more than one monitor at 1080p+ resolutions.
I'm not planning to upgrade until there's something this rig can't play, suspect I've got at least another year in it before it's time to change socket (fingers crossed).
26-08-2011 9:57 PM
27-08-2011 10:31 AM
28-08-2011 11:19 AM
The mouse control is however rotten although having separate vertical and horizontal sensitivity is a big advantage.
28-08-2011 5:12 PM
28-08-2011 5:23 PM
29-08-2011 7:26 PM
but with the CM storm you can have seperate speeds for the X & Y axis in the mouse settings as opposed to the game,s and 4 DPI settings on the mouse buttons
31-08-2011 12:44 PM
Quote from: Oldjim Of course the next thing is whether my rig will even run it properly
Installed last night. Looks and plays great. Runs fine on my rig. Q6600, 2GB DDR2, 8800 GTS 512MB on medium settings.
01-09-2011 7:26 AM
alex looks like you need to update your GFX card , lol it was released in 2007
i run it maxed out on mine AMD athlon x4 645 3.1 , 4 gig ddr3 , crossfire 2x ati 6870,s = 2 gig ram total
19-09-2011 2:35 PM
My current rig is now:
- Intel i5 25000K running @ 4.4GHz
- 8Gb of Corsair DDR3 RAM @ 1600MHz
- 1Gb Gigabyte GTX460 GFX card
- ASUS P8P67 Motherboard
I've also got a Roccat Kone gaming mouse, and if I can justify the £70, a Roccat Isku keyboard when it gets released in a weeks time.
DXHR runs fine on top settings (as you can imagine). Then again, the graphics aren't particularly heavy anyway, probably due to the fact that it was developed for consoles as well.
**shakes angry fist at consoles**
19-09-2011 2:51 PM
Now to hope I haven't killed anyone by accident and I will get the pacifist achievement at the end. It's a pity there isn't a flag up saying pacifist failed
