Destiny - Anyone having connection issues.
- Gaming
- Destiny - Anyone having connection issues.
Re: Destiny - Anyone having connection issues.
24-09-2014 12:26 PM
Quote from: ghos7em1 @ryoga ids config state=disabled
Yeah, I've already checked on Telnet. It says it is disabled. I'll try sticking the PS4 on DMZ. WIll let you know of the outcome...
Judging by the hearsay around the internet, Destiny uses P2P to connect to many different players at any one time. Does Plusnet throttle P2P traffic in any way? Is the TG582n router capable of handling thousands of connections from different unique locations through P2P?
24-09-2014 4:12 PM
24-09-2014 8:47 PM
Quote from: Ryoga
Still getting issues, even when my PS4 has been assign to the DMZ. Disconnects me with the Beaver error message. The strict NAT error message is gone though.
25-09-2014 8:43 AM
25-09-2014 8:49 AM
25-09-2014 2:47 PM
Sometimes I can play for a good hour and then I get the sudden error messages and log off. I do a test on the multiplayer connection and I get a HIGH PACKET LOSS.
I have enabled gaming mode, un ticked extended fire wall, and I have tried DMZ.
25-09-2014 4:11 PM
We've been testing on ADSL though, are you all fibre?
Ex-Broadband Service Manager
25-09-2014 5:24 PM
Quote from: Kelly We've been trying to replicate this and we can't
I am on ADSL still.
Is it possible to get my line tested at your end Kelly please?
DSL Type: ITU-T G.992.3
Bandwidth (Up/Down) [kbps/kbps]: 905 / 5,635
Data Transferred (Sent/Received) [MB/MB]: 14.75 / 148.89
Output Power (Up/Down) [dBm]: 12.8 / 0.0
Line Attenuation (Up/Down) [dB]: 31.0 / 51.5
25-09-2014 8:52 PM
I'm on Plusnet Unlimited Fibre with Pro Add-on.
Firmware on TG582n router is 10.2.5.2
25-09-2014 9:50 PM
26-09-2014 2:48 PM
Maybe this issue is to do with the router some are using?
26-09-2014 2:50 PM
Quote from: Justin7 I'm using Plusnet fttc with a decent new netgear router and since the update Plusnet made to the traffic management system the game has worked great on ps4.
When was this update you speak of?
26-09-2014 8:25 PM
After the update the other day.
See this link towards the end.
http://community.plus.net/forum/index.php/topic,129492.16.html
Have you tried it recently?
27-09-2014 6:58 PM
are you still getting issues?
27-09-2014 7:11 PM
