Destiny - Anyone having connection issues.
- Gaming
- Destiny - Anyone having connection issues.
Re: Destiny - Anyone having connection issues.
22-09-2014 7:00 PM
Ex-Broadband Service Manager
23-09-2014 5:44 PM
24-09-2014 12:26 AM
Quote from: Haffoc
Quote from: Ryoga
Quote from: ghos7em1 if upnp extended security is disabled only thing you can do is use dmz option,if that dont sort your problem then you will have to buy a better router
uPnP Extended Security has been turned off now.Will find out if that has helped.Nope, didn't help one bit. Still getting 'Beaver' error message upon connecting to the Tower part of the game.
When the error happens, are you able to see the Technicolor router?
The reason I ask is that Destiny seems to do something funky to mine. At the time I get disconnected and get an error, the router will show only the broadband led, then the ethernet, Internet and wifi leds, then the broadband led, then back to ethernet internet wifi. It will repeat this about 5 times, then either resets, or recconects.
Destiny is the only time this happens, so its something the game is doing.
I am having exactly the same problem with Destiny on PS4 with the tg582n. When the Destiny connection drops, my router seems to hitch and I lose connection with my phone too. My ps4 is wired, so it's not the wifi. Making it unplayable.
24-09-2014 2:30 AM
24-09-2014 8:58 AM
Is this a setting available when going into the router via PC?
I'm not at home so can't give it a go right now.
I get loads of connection issues when playing Destiny. Plusnet tested my line and said there were no disconnections - hwoever when using speedtest.net 20 times on Sunday evening I seen the connection drop for 1-2 seconds every 5 minutes or so - the speed would be 65-70 during the test but at some point drop to 0.
When playing Destiny, chatting to friends and streaming live sport on Laptop, chat and stream would stop at the exact same time that Destiny lost connection. However, I recently tried those things without Destiny and they worked all night without issue.
So it's as if Destiny is dropping, which then does something to the router - not fully disconnecting it (so plusnet don't see an issue) but it glitches it enough to lose connection very briefly.
7/10 evenings it's totally fine - so it's not a massive issue but when it does happen it's really bad
24-09-2014 9:38 AM
24-09-2014 9:50 AM
24-09-2014 10:06 AM
24-09-2014 10:49 AM
24-09-2014 10:55 AM
I have had no problem with Titanfall or Xbox live chat, tried to play Destiny last night and it kept kicking me out, telling me i wasn't connected etc despite talking to a friend through headset at the same time.
I tried connecting to modem directly via ethernet, that didn't work, I forwarded all the required ports, I turned router firewall off, I disabled UPNP, I put the console in a DMZ and it hasn't appeared to have worked - albeit when I removed the port forward and kept just DMZ on it seemed it may have done something but it was late by then so had to call it a day.
Spoke to the plusnet rep while doing all this and they were very helpful and did go above and beyond in guiding me through things including trying to connect via PPPOE to discover whether this could be fixed (something we discovered that cannot be done with ease on the xbox)
In the end hes sending me a new router which both he and I have little hope for. I may have to try a better router considering the Technicolour one is absolutely awful and seems to enjoy restricting alot of things.
If anyone has any fix for this or if Plusnet could release some kind of official post about this it would be helpful - In regards to the last few posts I had two other people next to me who had zero issues in connecting to e-mails or online poker, I also had no issue talking to a friend again over xbox live chat or any issue playing titanfall online
24-09-2014 11:01 AM
Please retry with the XBone in the DMZ without the forwarding rules. It's likely that with the Xbox in the DMZ, but with the forwarding rules in place that you'll have found issues.
24-09-2014 11:12 AM
As for the new router I requested it, he explained it wouldn't do anything but considering at this point I was at the end of my tether I said I might as well try all possibilities - especially if I have to go and purchase another router - not something im keen on having just spend £400 on bloody xbox!!
24-09-2014 11:14 AM
24-09-2014 11:25 AM
Will try with my current one and check all my settings again to ensure its only in the DMZ without ports forward.
One question with that - I set my Xbox One's IP address as static when I forwarded all the ports, when putting the Xbox in the DMZ should I keep the IP static or uncheck that?
24-09-2014 12:03 PM
