DIscord Users
Fixes: 9
Re: DIscord Users
Do you also have servernames/IPs for the servers you can't connect to?
Kelly Dorset
Broadband Service Manager
Re: DIscord Users
Hello. I've also been effected by this. Happy to lend a hand if you need me to get some info
Fixes: 9
Re: DIscord Users
Is it still happening?   We suspect this is an issue on Discord's side, but happy to take a deeper look if we can replicate.
Kelly Dorset
Re: DIscord Users
It seemed to have sorted its self out since and I was able to use it the following day. Cheers for looking in any case.
