how to set NAT to open on PC cod warzone? (mines set to moderate)
FIXED- Subscribe to RSS Feed
- Gaming
- how to set NAT to open on PC cod warzone? (mines ...
01-05-2020 11:48 AM
Can anybody tell him how i input those ports into my plusnet router to set NAT to open? i just give it a go and my NAT is still moderate.
Fixed! Go to the fix.
01-05-2020 12:26 PM - edited 01-05-2020 12:28 PM
Try this:
You should have seven rows: two TCP + five UDP.
If one port is given by the list put the same value in "From" and "to".
If a port range is given in the list put the lower value of the range in "From" and the upper value of the range in "to".
So the first two rows should look like this:
| From | to | Protocol | From | to |
| 3074 | 3074 | TCP | 3074 | 3074 |
| 27014 |
27050 |
TCP | 27014 | 27050 |
You can do the UDP ones.
I can't remember the last time I had to configure port forwarding for a game -- you may wish to check the firewall settings on your PC (e.g. Windows Firewall) to make sure it is not blocked there. On Windows also watch for the different rules for "public" and "private" networks and check which your network is configured as within Windows.
Re: how to set NAT to open on PC cod warzone? (mines set to moderate)
01-05-2020 12:38 PM
Awesome!!!
it worked. appreciate the help.
this doesnt put security of my computer at risk or anything right?
01-05-2020 1:01 PM
Glad to hear it ![]()
I can't imagine security being an issue on those ports. If the NAT rule was for something like a remote management tool it would be something to think twice about.
01-05-2020 1:04 PM
okay thats good to know.
i dont know why plusnet doesnt update the gamelist selection thats on their router, would save so much hassle for people wanting to port foward to open NAT. the list they got on there is like 10 years old. needs updating.
- Gaming
