DG834N & PS3 (Help)
- Gaming
- DG834N & PS3 (Help)
DG834N & PS3 (Help)
04-01-2009 12:40 PM
This is my first post since joining Plusnet and am hoping some one could help...
I have a DG834N with DGTeam0848 firmware with Upnp enabled in the menu,however
the PS3 is reporting Upnp as unavailable but still NAT type 2. Also what i thought was odd is-
after the PS3 has signed in to the PSN it shows in the port table on the router that the PS3 opened them.
If anyone knows whats going on with this as i am now out of my depth
Re: DG834N & PS3 (Help)
04-01-2009 1:03 PM
04-01-2009 2:10 PM
If Upnp was not working as the Ps3 says would it connect and sign in with the connection settings set to automatic?(without port forward or DMZ)
04-01-2009 3:03 PM
05-01-2009 8:03 PM
any one had this of know how to fix..?
05-01-2009 8:28 PM
If that doesn't work try checking and tweaking your MTU settings, have a look at http://www.kitz.co.uk/adsl/tweak2.htm
05-01-2009 8:51 PM
Then it signed in and i could get the pages up,like nothing was wrong.Without changing anything!
05-01-2009 9:19 PM
05-01-2009 9:54 PM
Quote from: alex1937 A community member had a issue with this router, have you updated to the latest firmware (v1.02.08) if so he had a lot of issue's with it on the xbox 360 that may be causing you the issue.
yes the firmware is (v1.02.08 DGTeam) ..i have read there is a v1.02.13 but dont think its on the netgear web site yet..
09-01-2009 12:54 PM
09-01-2009 4:53 PM
Quote from: alex1937 Did you get the issue sorted? if not try rolling back to the old firmware see if that helps.
I found the v1.02.13 firmware and tried all the DGteam versions but the DG834N is the still the most unstable router i have ever used.
I have returned it today .. I am now doing some home work as to what to get next.
It wont be a Netgear for sure.
Router needs to have SNR adjustment or work with DMT tool.Traffic management for PS3 ,wireless and be stable!....if anyone knows of such a thing?
09-01-2009 6:32 PM
09-01-2009 7:21 PM
Bob
10-01-2009 12:06 AM
http://www.amazon.co.uk/Netgear-DG834G-54Mbps-Wireless-Firewall/dp/B0000TZ8Z8
10-01-2009 5:20 AM
