Better Latency
- Gaming
- Better Latency
Better Latency
20-02-2009 2:20 PM
I just got activated today and my pings are still not what I would like, I am getting around 70ms in all UK servers.
Can i try with interleaving turned off, and how would I go about doing this?
Username is: Gerald116
Cheers.
Cheers.
4 REPLIES 4
Re: Better Latency
20-02-2009 2:34 PM
You need to raise a ticket to have interleaving removed, https://portal.plus.net/wizard/index.html?help_action=tdl01
Re: Better Latency
20-02-2009 3:14 PM
No need for a ticket theres an option in connections settings, if not https://portal.plus.net/my/account_maintenance/interleaving_control.html is a direct link
Unvalued customer since 2001 funding cheap internet for others / DSL/Fibre house move 24 month regrade from 8th May 2017
Re: Better Latency
20-02-2009 3:16 PM
Some do, some don't.. depends what package you are on.
Re: Better Latency
20-02-2009 11:10 PM
i got the interleaving on member centre when upgraded to max upload and on changing to unlimited i got ip static menu.
on the minus side thoe alot more things have gone than bein added
