random speeds...
- Full Fibre
- random speeds...
random speeds...
05-10-2010 8:21 PM
can we get a bit of focus on why some of us are getting very slow and almost random throughput during the evening?
i am quite often a factor of 10 worse off than on adsl2+
this is clearly a fttc issue i think?
i'm also on pro and don't really appreciate paying extra for a service that i'm clearly not getting.
at least i would like an update from plusnet on what they think the issue is and a plan for addressing it.
this is what the trial is for isn't it?
cheers
pete
Re: random speeds...
05-10-2010 8:47 PM
As for the slow down, I suspect that's Plusnets throttling, I can't watch streaming media in the evening at all, and my ADSL2+ is rated at 19mb
05-10-2010 9:31 PM
Quote from: fourfourdevon Paying extra?I suspect that's Plusnets throttling
yes i am paying extra to be on the pro product which is supposed to have no throttling at all
05-10-2010 9:36 PM
it's pretty mad that my upload is faster than my download...
05-10-2010 9:39 PM
05-10-2010 9:42 PM
so maybe you are correct and it is soemthing that dave can fix
do you know what was done?
Dave are you around? Can you work your magic 🙂
07-10-2010 8:47 PM
Have you tried rebooting both the BT modem and your router? I'll have a look when I'm back in the office tomorrow to see if I can see anything wrong. I've seen a few cases like this before and a reboot does help a lot of the time.
Plusnet Technology
07-10-2010 11:44 PM
Quote from: dave Have you tried rebooting both the BT modem and your router?
to repeat what i've said elsewhere...
but why would that help and why does it all go back to normal the next day, it's clearly something that is time of day dependant.
to be quite frank asking me to reboot is just the same as 'is it plugged in, have you turned in off and on again'
it's not helpful and it doesn't tell us what is going on
we'll see what you find when you get in..
08-10-2010 11:45 AM
Plusnet Technology
08-10-2010 1:34 PM
your support team will get overrun
08-10-2010 3:20 PM
Plusnet Technology
08-10-2010 6:29 PM
bit odd how this is only happening on fttc though as i hadn't seen this on adsl2+
will try a reboot next time i notice it and report my results
09-10-2010 12:37 AM
anyway it has has absolutely no effect whatsoever
one thing i should emphasise is that these speed problems tend to only occure at last night time
and that's another reason why i don't think it's contention...although i sppouse torrents could be running overnight
out of interest are bt throttling/capping the bandwidth running along FTTC?
09-10-2010 9:58 AM
I think BT must recognise that they don't have enough bandwidth for full speed all the time.
This is what I got from their speedtest yesterday
Best Effort Test: -provides background information.
Download speedachieved during the test was - 8271 Kbps
For your connection, the acceptable range of speeds is 8000-28532 Kbps .
Additional Information:
IP Profile for your line is -28532 Kbps
Previously they had the lower limit at 10000 not 8000
Further they said:
We were unable to identify any performance problem with your service at this time.
It is possible that any problem you are currently, or had previously experienced may have been caused by traffic congestion on the Internet or by the server you were accessing responding slowly.
That will include their own speedtest even when logged in as a BT test user will it?
If you read through the consultation document from 2008 (publicly available, found by Google) you can read:
Openreach has consulted with other network operators globally to determine network configuration models that make for good quality service to CPs and their end users and we believe that the tiered service structure with defined Minimum Assured Rates makes for the best service as it provides a clear limit on end user ability to train up to the maximum line capability rate; without these controls this can lead to issues with service quality and resultant disputes. Openreach believes that a tiered pricing structure linked to bandwidth combined with setting a peak rate limit is the most sustainable market model because:
␣ It makes for a lower price entry point for customers wanting lower grade service. ␣ It enables CPs to test the market take up at several pricing points with appropriate products
within which they can dimension their own tiered product offerings
␣ It introduces minimum levels of service that would not be enabled through a flat pricing model.
␣ It enables the calculation of assured bandwidth rates which would not be possible through a flat pricing model where lines were allowed to run at maximum rates.
␣ It stops there being a possibility of one user’s service impacting adversely on another's which could be the case using a flat pricing model where lines are all allowed to run at maximum capability.
␣ It enables Openreach to more cost effectively plan and build the access and backhaul to meet CP demand and to deliver a consistent and equivalent service to all.
␣ It recognises the additional costs inherent in supporting higher speeds of service.
They wrote about peak and assured rates as follows (see image attached):
09-10-2010 12:28 PM
I have been on FTTC since Thursday afternoon.
My first test and my most recent are attached. SInce the first, download speed has been > 32Mbps. Upload has been rock steady on.
BT Speedtest is a little lower.
I should point out that I am the BT engineer told me that I am first user to be connected to the local cabinet.
Dave
