What's the deal with routers?
khaled35
Re: What's the deal with routers?
@Townman incidentally, both sockets looked identical to me and have the same letters across the top. Maybe the internal parts are different, but I wouldn't know.
Fixes: 240
If it is the very latest NTE5, the face plate should come off with a gentle squeeze and reveal another phone socket - that is the test socket.  Any internal wiring to other sockets should be connected to the faceplate.  I have though seen them installed incorrectly, the extension wiring being taken off the back of the backplate thereby totally defeating the purpose of the isolation point.
TheMightyAJ
Fixes: 126
@Townman, the DLM doesn't seem to have been touched by the engineer, though when I tested the line earlier this morning the profile looked okay. I've already confirmed this with @khaled35 via a support ticket, but I'll be keeping an eye on the connection over the coming days and if anything further needs to be done, I'll get right on it Smiley
 Alex H
briston
You mention customer loyalty. Plusnet do not operate customer loyalty, charging more to renew a contract than it you were a new customer.
Fixes: 102
It's quite simple - PlusNet have a basic price with which they calculate then can make a profit.
As part of their overall costs they probably have a marketing budget to attract new customers - hence the discount.
If everybody got the new customer price then PlusNet would probably go bankrupt. It'll be the same in any business where now customers get better prices than existing ones.
Moderator's note by Dick (Strat): Full quote of preceding post removed as per Forum rules.
khaled35
@bmc running what amounts to a subscription based business isn't just about attracting new customers. Customer retention is also a major factor.
Fixes: 102
True.
But doesn't change the basic fact if a company dosn't charge enough for it's basic product it'll get into financial difficulties.
Moderators Note: Full quote of preceding post removed.
stevewx
@khaled35
It sounds like your line has been 'banded'.  Happened to me 2020 into 2021.
My U/L speed was always 19999
My connection speed was up to 76000, but my D/L NEVER went above 59999.
Opnreach visited, could not understand, Explained line banding, and I did have a fault report from lusnot says 128k-60M.
Talked the engineer into calling India.  It was fixed by that signal phone call. My need for an enginner to come and scratch his head.  He went away happy as he had learned something he could use.
Get Plusnet to down a line test, then read the report.  Does it say 128k to 55M or similar?
And a month ago I talked Plusnet into sending my out the latest router for just £6.99 P&P.
Currently line is connected at 80005 and D/L is 78362.  The new router is better than anything I saw with a couple of Home Hub One's.
I'd call and for a Hub 2, sort of pester in a nice way and don't give up.  Also check any line test results.  They will be in the Ticket sent as a reply.
Good luck,
Steve
