Openreach socket installed but Plusnet says that a BT socket is required?!
Oti78
Good day,
I am moving home and the new property has an Openreach socket. However , when I try to purchase a broadband package from Plusnet, it says that I will need a BT socket and have to pay 50 pounds for the installation.
Do you know why I am getting this message?
6 REPLIES 6
Fixes: 480
Re: Openreach socket installed but Plusnet says that a BT socket is required?!
@Oti78
I suspect that you are really being told that you have to pay an installation charge even though you have a BT socket?
If the connection to your new home is dead, that is there is no existing service on the line, then work is required at the local exchange and/or fibre cabinet. In these circumstances this is considered to be the installation work for which you will be charged.
Fixes: 579
or if the existing service was an LLU provider (Sky/Talktalk) then an engineer is still required at the exchange to reconnect the line to the BT equipment
Oti78
thank you both for your prompt replies.
I assume that the previous tenant had indeed Sky as I can see 2 cables.probably for the sattelite dishes
1) @Baldrick1  Is there any way to check if the line is indeed dead?
2) @MisterW So if I were to choose Sky instead of Plusnet, would a visit from an engineer still be required?
Fixes: 579
Plug in a phone and dial 17070 , if its an active BT line , it will report the circuit Id and phone number
You would need to ask Sky if there is an installation charge
Fixes: 480
@MisterW
I believe that LLU transfers are free. It's only new lines, reconnecting either a BT or LLU service that are chargeable  https://www.plus.net/help/legal/plusnet-price-guide-for-residential-products/
Fixes: 1,662
Thanks for your post @Oti78
Just to back up @MisterW and @Baldrick1 as their advice is what I'd have said also.
Let us know if you've got any further queries.
