Weird things..... [FTTC]
- Full Fibre
- Weird things..... [FTTC]
11-05-2012 10:39 AM
I'm on the FTTC 80/20 trial using the ZyXEL router. However I noticed some strange things.
I basically the "ICT Tech" of the family, therefore I look after my parents Plusnet account as well as mine. (they live two streets away lol) They are on the normal value 40/2 fibre. I'm on the extra 40/2 with pro but upgraded to the trial 80/20.
Few things I noticed.....
My parents account reports 37mb line speed in the member centre, mine says 20mb.
Their download speed hit the 37mb and their upload speeds just under the 2 - other words perfect connection.
Mine did exactly the same before getting the 80/20 trial.
When I got the trial, to begin with I got speeds of 60+ on downloads and 15+ on uploads, impressive and I was well happy.
Now it dropped to around 20-38mb download (depending on speed testers used) and around 10/11mb on uploads. So why this happened?
Results from BT speed test.....
Download Speed
32 Mbps
0 Mbps 51.12 Mbps
Max Achievable Speed
Download speedachieved during the test was - 32 Mbps
For your connection, the acceptable range of speedsis 12 Mbps-51.12 Mbps .
Additional Information:
IP Profile for your line is - 51.12 Mbps
Upload Speed
7.21 Mbps
0 Mbps 20 Mbps
Upload speed achieved during the test was - 7.21Mbps
Upstream Rate IP profile on your line is - 20 Mbps (<- is that what the member centre reporting on?!)
Speedtest.uk.net reports this below.
Thoughts guys?
(I tell you one thing, since getting this 80/20 I host nearly every game on Modern Warfare 3 on Xbox Live and it often makes it WORSE lol!)
Re: Weird things..... [FTTC]
11-05-2012 11:55 AM
Not sure what's happening there but from what you've posted I think raising a fault would be the only way we could deal with it to be honest. If you raise it through http://faults.plus.net we'll get it tested and escalated as soon as we can.
11-05-2012 12:55 PM
jim:quote
11-05-2012 12:56 PM
11-05-2012 1:54 PM
11-05-2012 3:29 PM
11-05-2012 3:39 PM
11-05-2012 3:45 PM
Sometimes..... Plusnet is too good 🙂
BT Speedtest showed a lower result, but the other was similar to the previous result.
Will test this evening, see where it goes.
11-05-2012 4:15 PM
11-05-2012 11:35 PM
Quote from: Matt Just to say, I've seen people get around the lag compensation issues by streaming a video at the same time as they're playing the game. Not sure if it'll work but could be worth a go
I will try a BBC iplayer to see if it makes a differnet - obviously with this speed, maybe a HD stream! I'm going to try and use traffic control on the ZyXEL router - once I figured it out.
Latest speed just done
BT speedtest reports same download speed but 9.94 on the upload. Close enough I guess
Connection more stable now, so I will see how the next few days go.
Whats the general feedback with the ZyXEL routers and the original Netgear ones?
12-05-2012 3:28 PM
14-05-2012 11:15 AM
