FTTC Router that supports multiple IP addresses
- Full Fibre
- FTTC Router that supports multiple IP addresses
11-05-2012 9:48 PM
Can any one reccomend a cheap router that supports Multiple IP addesses (either by diableing nat or using one-to-one nat)?
The DG834 did it nicely (and probibly still could if i could work out a way to dig around in the firmware to change the wan port).
Message 1 of 5
(1,994 Views)
4 REPLIES 4
Re: FTTC Router that supports multiple IP addresses
13-05-2012 12:37 PM
If anyone wants to know Windows 2003 Routing and Remote access makes a good PPPOE router with the ability map Multiple External IP Addresses to internal ones.
Message 2 of 5
(664 Views)
13-05-2012 12:49 PM
Are you on a business FTTC tariff? I asked for a couple of static Ip's on my new FTTC connection (fibre extra) and was told I couldn't have it.
Message 3 of 5
(664 Views)
13-05-2012 3:43 PM
I have had these IPs for years and yes it's a business tarrif.
Message 4 of 5
(664 Views)
14-05-2012 2:03 PM
All the Zyxel routers I have used (ADSL & Cable) have done this...
Disable NAT and allocate the same IP (your WAN default router address) to both the LAN and WAN interfaces...strange but it works.
Message 5 of 5
(664 Views)
- Full Fibre
