Weekend Broadband Activation
Browni
Aspiring Hero
Fixes: 61
Re: Weekend Broadband Activation
mariar98
Thanks!
Unfortunately I'm still not able to actually use the internet. It's still showing an orange light with the broadband flashing red. What do I do now?
Fixes: 1,662
I’d recommend running through the checks here: https://community.plus.net/t5/Library/Testing-From-The-Master-Socket/ba-p/1322242 and reporting a fault to us at http://faults.plus.net if the checks don’t help. Let us know how you get on.
mariar98
Yep same issue persists and testing e socket made no difference. I'm going to buy a cheap phone to test the dial tone tomorrow then report any faults
mariar98
Okay so I didn't get a dial tone from the phone (including using the test socket) so I've just reported the fault.
Hopefully it won't take too long to fix, and thanks for the help!
Chris
Legend
Fixes: 169
I've tested your line and updated the fault ticket, if you can take a look here and reply directly to the fault ticket that would be great. https://www.plus.net/wizard/?p=view_question&id=155361035
mariar98
Great thanks
Chris
Legend
Fixes: 169
That's all booked in for you, I've confirmed the date on the ticket. Let us know how the visit goes.
