What is kci3
shrubb2121
What is kci3
3 weeks ago I placed an order with BT for phone and fibre i cancelled this order with BT the next day I was told i will remain with plusnet but some reason BT placed kci3 on my line in a result my plusnet fibre has lost connection red broadband light on plusnet hub one is flashing I've been without no fibre for around 10 days now.
5 REPLIES 5
Mustrum
Fixes: 81
Re: What is kci3
I believe kci 3 just means order complete. Have you reported a fault?
shrubb2121
Re: What is kci3
I've had so much stress sorting this mess out over 10 days now plusnet keep giving me different stories I've told them not back on by middle of next week I'm buying out a new line from another provider.
bobpullen
Fixes: 330
Re: What is kci3
KCI = Keep Customer Informed.
It's basically a notification send from a supplier to update on the progress of a particular activity like a provisioning order or fault.
In broadband/landline terms, KCI 3's are typically received when a provisioning order completes.
shrubb2121
Re: What is kci3
Thanks looks like BT have caused this mess in a result my Plusnet fibre has gone off red broadband light flashing on my hub one router how can BT process this when I cancelled order with BT very next day but my landline is working fine
Fixes: 1,652
Re: What is kci3
It looks like the cease order is stuck on our suppliers systems, so it didn't cancel. I believe that's in hand with our provisioning team and we're awaiting for updates from our suppliers.
In the meantime, the service is still active with Plusnet, but line tests are pointing towards a jumpering issue at the cabinet.
I've reported this through to Openreach to investigate further. Likely that once the cease order completes we'll need to reprovide the service, but this should give you service until that happens.
