Upgraded from 300 to 500
- Full Fibre
- Upgraded from 300 to 500
23-12-2025 4:20 PM
Re: Upgraded from 300 to 500
23-12-2025 4:31 PM
when i do a speed test, still reading 150 download
Is that a wired or a wireless speed test ?
23-12-2025 4:52 PM
23-12-2025 4:55 PM - edited 23-12-2025 4:57 PM
Strange, the change to 65Mb upload would suggest that a change has certainly been made. I think you're going to have to call in and get someone to check what's happened
NB have you tried a different speed test , I usually find the Ookla speedtest.net reasonably accurate at the higher speeds
30-12-2025 9:24 AM
Morning,
I have the exact same problem. Upgraded from 300 to 500 package and my download as gone done to 150 while my upload has gone up to 69.
I’ve tried the usual help options and connection refresh no luck.
To me it feels like the order bot hasn’t processed the upgrade correctly.
Can someone from plusnet please DM me?
Thanks,
Andrew
31-12-2025 9:48 AM
Morning @Andyuk
Welcome to the community.
Just to check, have you been in touch with our customer service team by text or calling since you posted on the community?
When did you upgrade?
Speak to you soon.
Leanne.
31-12-2025 10:12 AM
Yes, I’ve done the text based line checks and connection refresh options.
Checking my inbox, I upgraded on 17th December 2025. That’s the date on my “Your broadband product change is now complete” email.
31-12-2025 10:39 AM
