Slower than expected Full Fibre speed
and107
Hi All,
I upgraded to Full Fibre 900 which was installed on the 24/12/24. Was getting speeds of around 550MBPS with the best being up to 600MBPS. Last couple of days it seems to struggle to reach the minimum and the latest speed tests I have done are giving about 447mbps but has been lower today. We were supplied with a new Hub 2 Router and I wonder is there any change of config needed at all?
I can attach the log if that would help?
Thank you in advance
Screenshot 2024-12-30 at 4.46.19 PM.pngScreenshot 2024-12-30 at 5.05.33 PM.png
14 REPLIES 14
Fixes: 580
Re: Slower than expected Full Fibre speed
Are those speed tests on a wired connection ?
and107
It was on a wireless connection as my Mac Laptop does not have a network port.
Fixes: 580
Sorry but you really need a wired test to confirm whether there's a basic problem with the connection. Your speed tests are about right for a WiFi 5  wireless connection via the Hub 2.
Fixes: 1,495
With my MacBook Pro I see this wireless:
and this is wired:
This is the adapter I use https://www.amazon.co.uk/gp/product/B07M8GSLQB/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1
and107
Thank you Hopefully this will work and I can test on a wired connection
and107
Thank you for your helpful advice and will try the wired approach
redsox9
Fixes: 4
I see too many complaints about slow Internet speeds. Is this the answer?
Moderators Note: Advertising link removed
Is this a cynical attempt to advertise?
https://www.reviewopedia.com/wifiblast-reviews
https://uk.trustpilot.com/review/wifiblast.com
Fixes: 383
@Dan_the_Van I thought @redsox9 (who has been on the forums for 9 years) would have more sense than to believe an item clearly marked 'repeater' would do what the claim in his post said, disregarding the fluff from the 'engineer' - which is obvious lies.
Fixes: 1,495
The bottom of the (now removed) link says:
"THIS IS AN ADVERTISEMENT AND NOT AN ACTUAL NEWS ARTICLE, BLOG, OR CONSUMER PROTECTION UPDATE"
Fixes: 383
Thanks, @dvorak  - I gave up reading before I got that far, it was so blatantly wrong.
redsox9
Fixes: 4
@Dan_the_Van
Thanks for shooting it down.
Fixes: 246
@redsox9
This is utter nonsense!!!
If the “problem” is router throttling (that is reducing the speed / throughput between the router and the internet) over time then “fixing” the local WiFi network (by whatever means) is not going to address the discussed “problem”.
Yet more technology FUD to beguile people into parting with their cash, without thinking through the claims.
EDIT: drafted earlier in the day but not sent … after doing so I can now see the various updates. Arrived at the “party” later than intended!!
Once I started to read the supplied link it was clear that it was an advert.
Can't blame me for the number of negative reviews of the product.
