Serious speed issues.
- Full Fibre
- Serious speed issues.
- « Previous
- 1
- 2
- Next »
Re: Serious speed issues.
19-07-2023 12:44 PM
Absolutely @bill888 - you're unlikely to get much beyond ~300-400mbps over Wi-Fi in favourable conditions using a Hub Two. This depends equally on the capability of the wireless devices you have connected to it, e.g. a 2.4GHz only device is unlikely to get into the hundreds.
19-07-2023 2:54 PM
@nathannchan hasn't posted the speed test results that I received via PM a few hours ago.
Using ethernet:
speedtest.net - looks awfully slow?
fast..com
I don't recognise this speed tester
The bottom two images would suggest it is a 900 Mb FTTP service being supplied by Openreach/Plusnet.
I just tried speedtest.net on my BT 500mb with same Youfibre server.
Looks like the youfibre server can't deliver 500+ Mbps speeds during speed tests.
@nathannchan also reported their hub 2 cut out twice in 30 minute interval earlier this afternoon. Orange light on front of hub appeared on both occasions. Reason unknown.
20-07-2023 9:41 AM
Interesting observation about the YouFibre speedtest.net server. I see similar. Not quite as low as the results posted here, but still ~300mbps lower than running the test against a different server.
- « Previous
- 1
- 2
- Next »
