Serious speed issues.
- Full Fibre
- Re: Serious speed issues.
17-07-2023 2:14 PM
17-07-2023 2:17 PM
What about a ethernet connected test?
17-07-2023 2:21 PM
Download: 120.2 Mbps
Upload: 58.2 Mbps
17-07-2023 4:35 PM
That doesn't look good. As Full Fibre is slightly out of my experience, maybe @MisterW can take over - I would hate to give wrong advice.
18-07-2023 3:40 PM
Sorry to hear this @nathannchan nothing is flagging from our side, however we can't see the speed on our side. What checks have you done? Just so that we have the full picture.
18-07-2023 3:43 PM
Hi Will,
I've tested over WiFi and also ethernet. I'm still not getting anywhere near the guaranteed minimum 500mbs
18-07-2023 6:27 PM
@nathannchan - are you posting here whilst connected to your Plusnet line?
18-07-2023 7:52 PM
18-07-2023 10:27 PM
When I first replied, the last IP address you posted from was owned by ZScaler (not Plusnet).
This latest reply is from an O2 IP.
Could you perhaps be speed testing from a corporate laptop that has some sort of proxy/VPN service installed? If so, your speeds could well be limited to whatever the VPN/proxy tunnel can support.
18-07-2023 10:52 PM
19-07-2023 9:36 AM - edited 19-07-2023 9:39 AM
fwiw, you haven't said what router 'hardware' you use and although it is unlikely to be the cause, could you perhaps use another router such as a Plusnet Hub 2 ?
Alternatively, connect an ethernet wired Windows PC direct to the Openreach modem and run a speed test?
https://www.tp-link.com/uk/support/faq/921/
If you enable ping on your router, you could also set up a BQM to detect any packet loss.
https://www.thinkbroadband.com/broadband/monitoring/quality
Other thought is whether you have enabled QoS with incorrect settings on your own router?
19-07-2023 9:45 AM
19-07-2023 9:50 AM
19-07-2023 10:23 AM - edited 19-07-2023 10:27 AM
There are no settings you can change on hub 2 that would affect ethernet speed tests.
There was a recent firmware update for the hub 2.
I can only suggest you wire an ethernet PC direct to the openreach modem to run a speed test, to rule out the possibility the hub 2 is defective. Also to set up BQM to check for packet loss (remember to turn on Ping on hub 2) after a few hours use.
Can you provide an 'image' from the speedtest.net result. Run the test several times to get consistent results and try a selecting a different server.
19-07-2023 11:35 AM - edited 19-07-2023 11:50 AM
fyi, update from @nathannchan who sent me this image via PM of a speed test over 'wifi' via Hub 2.
Upload speed looks fine to me.
Speed test to be checked using an ethernet wired computer, because Wifi-5 (802.11ac) enabled Hub Two won't ever reach 900 mbps over wifi-5. (2x2 Wifi-5 may max out 460-480mbps)
