Re: Slow broadband
- Full Fibre
- Re: Slow broadband
Re: Slow broadband
yesterday
Re: Slow broadband
yesterday
@Michael16 Can't really comment on the cables issue as it is slightly out of my skill-set, but to add files on a mobile device, you need to request the desktop site.
Re: Slow broadband
yesterday - last edited yesterday
before you go into wholesale cable swapping, as @PhilipHeyes said , check the WAN link speed shown on the router status
login to the Hub/Router and check the WAN speed and the LAN speed.
if you computer is network connected check the link speed shown again is it 10/100/1000 ?
It should always show 1000, if it doesn't then that is the problem.
It may be down to a cable fault but it could also be a connector fault on the router, we've seen one or two instances of this in the past
Does your router serial no start with 'R' ?
Re: Slow broadband
yesterday
Cat8 cable is very stiff, are you putting any strain on any of the Routers, LAN/WAN ports.
With the Hub Two the event log does detail port disconnections.
If you look at the event log at the exact time a device connects to the Hub you will see the connection speed, the event looks like this
hh:mm:ss, DD MMM. Wire Lan Port 3 up, Speed 1000 Mbps <- this message is the port detecting a connection and negotiated speed
hh:mm:ss, DD MMM. A device connected to Ethernet port 3 <- this message confirms the connection.
For 100 Mbps it would be
hh:mm:ss, dd mmm. Wire Lan Port 3 up, Speed 100 Mbps
These messages are not categorised so no filter can be applied to find them, these messages clear after a while so a search on the event log may not find them.
A port down message
hh:mm:ss, dd mmm. Wire Lan Port 3 down, Speed 10 Mbps <- 10 Mbps is reported as speed negotiating starts at 10 Mbps.
Port can be 1, 2, or 3
disconnecting a LAN cable
hh:mm:ss, dd mmm. A device disconnected from Ethernet port 1
hh:mm:ss, dd mmm. Wire Lan Port 1 down, Speed 10 Mbps
Re: Slow broadband
yesterday
phone speed vs laptop both on wifi
Re: Slow broadband
yesterday
i have an image of the status page and can upload.
it has the broadband ip address, default gateway, primary and secondary dns if any of that is sensitive?
Re: Slow broadband
yesterday
@Michael16 Can't see any images yet. Those details are safe to leave visible, it is only your username and accountname which are sensitive.
Re: Slow broadband
yesterday
status page
Re: Slow broadband
yesterday
speeds comparison
Re: Slow broadband
yesterday
they should be up now?
Re: Slow broadband
yesterday
Can't see anything on the post 'Status' page, but your 'compared speeds' one looks a little strange - 630 on a wired(?) laptop vs 84 on the phone - suggests that the phone is on the 2.4Ghz band.
Maybe @Dan_the_Van or @MisterW would care to comment?
Re: Slow broadband
Assuming you are you using a Hub Two you can check which band (2.4 or 5GHz) your devices are connecting.
Look at the Hubs >Home ->My devices screen, this details which band.
Looking at the attached photo it suggests the phone is connected to 2.4 Ghz band and the laptop is 5 Ghz?
Re: Slow broadband
yesterday
My thoughts, too, @Dan_the_Van .
Re: Slow broadband
yesterday
If that 630Mb is wireless then TBH that's pretty good for a Hub 2. Given that it's only WiFi 5 I would have expected closer to 450Mb!
Re: Slow broadband
yesterday
