Plusnet Hub 2 Ethernet Cables
FIXEDTopic Options
- Full Fibre
- Re: Plusnet Hub 2 Ethernet Cables
22-09-2022 4:08 PM
Just a quick question - supplied with my Plusnet Hub 2 were 2 CAT5e cables, 1 red and 1 yellow.
Are these both the same, in terms of what they do ?
The red cable is a little bit too short to reach the table where I want to place the router, but the yellow one is longer.
Can I use that one to connect to the Openreach FTTP box on the wall ?
Cheers
Cheers
Fixed! Go to the fix.
Message 1 of 2
(2,948 Views)
1 REPLY 1
22-09-2022 4:14 PM
@TR11Falmouth Welcome to the Community forum.
Apart from the colour of the plugs the cables are identical, so swap away.
- Full Fibre
