Plusnet Hub 2 Ethernet Cables
TR11Falmouth
Just a quick question - supplied with my Plusnet Hub 2 were 2 CAT5e cables, 1 red and 1 yellow.
Are these both the same, in terms of what they do ?
The red cable is a little bit too short to reach the table where I want to place the router, but the yellow one is longer.
Can I use that one to connect to the Openreach FTTP box on the wall ?
Cheers
1 REPLY 1
Fixes: 479
Re: Plusnet Hub 2 Ethernet Cables
@TR11Falmouth  Welcome to the Community forum.
Apart from the colour of the plugs the cables are identical, so swap away.
